Audioguru
Advanced Member level 7
- Joined
- Jan 19, 2008
- Messages
- 9,461
- Helped
- 2,152
- Reputation
- 4,304
- Reaction score
- 2,008
- Trophy points
- 1,393
- Location
- Toronto area of Canada
- Activity points
- 59,758
The mic is powered and has about 2V to 3V on it. If you short the mic to 0V then it will be muted but the 2V to 3V transient will produce a hell of a loud POP!I would like to add mute switch with LED (momentary) in MIC circuit as attached by you in this thread.
pls suggest.
Mute the output of the preamp opamp instead since it does not have DC. You might need to use a Jfet to ramp down and up the volume during muting. I dun dat and it worked well.
If you use a flip-flop to cut power then apply power to the mic preamp then it will make very loud POP sounds.Is it possible to drive power to IC used in attached circuit from O/p of given below circuit(OP1 or OP2)?
but your circuit is too simple to power anything except an LED.
