Looking for fifo build by fpga
somayeh
Newbie level 5
building fifo by fpga
Hi people,
Could anybody go forward and build something?
Any interesting to share ??
Regards,
Re: building fifo by fpga
what is the problem ?
you can use xilinx coregen to generate fifo.
if you want to generate your own fifo, just use a DPRAM, with your own address counters, and control signals.[/i]
these documents might be useful if you are planning to design a fifo yourself
hxxp://www.geocities.com/deepakgeorge2000/vlsi_book/Asynch1.pdf
hxxp://www.geocities.com/deepakgeorge2000/vlsi_book/async_fifo2.pdf
    somayeh
You can easily build it. Try
Generate a set of registers and shift/rotate the data side by side for each clock cycle.
