mohansaini
Junior Member level 1
Hi All
I have to measure temperature of a DG(Diesel Generator) canopy by using a Microcontroller which will be around 5-10 meters from the DG to a control room.For that purpose wire length will be increased previously i was using 10K NTC which was not so far from the MCU. if i go for the same due to wire length change in resistance will be effected and will effect output so please suggest how can i achieve that.
Can i use LM35 which has a input range from 5-30V but output of LM35 will be the another problem.
Thanks.
Thanks.
