reddvoid
Junior Member level 3
I was checking logical equivalence between verilog and .lib using cadence conformal
I have verilog ports
but when I run the equivalence check I get the following error
But I have these ports clearly defined inside ifdef and ifndef
Do anybody have any idea about this? , would be very helpfull
Thank you
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 module abcd ( clk, d, o, sleep); input clk, d, sleep; `ifndef INTCNOPWR inout vcc, vcc_in, vssx; `endif output o; `ifdef INTCNOPWR wire vcc, vcc_in,vssx; 'endif
same for vcc_in and vssx.ERROR: inout port 'vcc' of module 'abcd' is not in the terminal list on line 7 at column 9 in file abcd.v
Thank you
