Load Sharing on Li-Ion Battery Charger
ste2006
Hi Guys,
I have been struggling with this issue for a while and cant seem to find a definitive reliable solution to what would seem like a common problem.
I basically have a GSM module that will operate between 3.4 - 3.8V. I also have a Li-ION charger IC that will charge up a 3.7V 1000 mAh Li-ION Battery for me.
Question is how do i connect both a DC fixed 3.7V supply and the battery supply to the system at the same time to if the main power source fails the battery will back it up and once normal power comes back it will switch back to this.
It generally seems not to be recommended to just place the load accross the battery being charged as if enough of a load is being drawn the battery management IC may never think it is charged??
I have built circuits using FETs, diodes etc but all give me a voltage drop which then brings my battery voltage down too low.
Peak current in bursts will be up to 2Amps so that also poses its own issues from the charger side. DC voltage starts at 5V and was just going through a regulator to step it down.
Maxim are showing on one of their IC's the load connected straight accross the battery (as attached) but Microchip then recommend not to do this!!
Anyone any thoughts???
Thanks,
Stephen
Thanks for the reply,
Yes i have already looked at this but it is a little more than i would like to pay and the leadless package is not ideal for prototyping, It also includes things like USB power which is no use to me,
I suppose i thought there might be a cheap simple standardised way of doing this that i did not know or could not find,
I would have thought it was a fairly basic requirement in a lot of systems no??
well $2 a chip adds up if you have more than a couple of them, Other problem with this is that i need it to be able to run 2Amps which this chip is not capable of doing, I am going to look at some other options of maybe using Power FETs to do the switch over, Ill let you know how i go, Thanks though for your help
