LM25011 failure on load
eriksen
Junior Member level 1
Hi, everyone!
I have built a relay board with a dc/dc regulator LM25011, a relay and a buzzer.
The problem I have is that the voltage drops already after putting a 50ma+ load onto it. And if I put a 30ohm resistor across the output (Equals 180mA current draw) the voltage drops to 0.8V and it can't manage to pull it self back up.
I have looked over the design and can't find any misplaced components or anything.
Specs the regulator is designed for:
Input: 10V-30V
Output: 5V@1.5A
Attached is schematic and a picture of my board. Any help would be greatly appreciated.
Thanks.
-Fredrik
  • BU_BOTTOM_SCH.pdf
i´d check the ratings of the inductor.
often inthe switcher´s datasheet there is a section about inductor selection.
Go through this.
And carefully read the inductor´s datasheet.
PCB looks good.
Klaus
