Linearization software program - freeware
yazou35
Junior Member level 1
data linearisation software
Hello,
I post here My LinSens softawre.
LinSens Linearization Software
Description :
LinSens is a linearization software. It was written to make linearization
of sensor data. It was tested with thermocouple and platinium temperature sensors.
The LinSens program accept ascii file data as input. Data Files must contains
numerical values separated by tabulation or space.
Data files are read as multi columns values. The first column is the X values
and the second column is the Y values.
A Direct linearization is an approximation of the curve y=f(x) by
polynomials functions. The user can choose the polynomial order and the maximum
accpted approximation error. The LinSens program search of the interavals
and compute the polynomials that approximate the y=f(x) function over each interval.
An Inverse Linearization make the same operation for the curve x=g(y).
