[SOLVED] line follower robot using stm 32 in keil u version with explanation
Noor Us Sabah
plzzzzz help me to find this code .....submissin date on this tuesday ,.....plzzz kindly
just google and get the idea and ask the question rather than full project.
Its nt found anywhere......
bt this code is not working point out mistake in it
#define  RCC_APB2ENR	( * ((volatile unsigned long*) 0x40021018))
#define GPIOA_CRL		( * ((volatile unsigned long*) 0x40010800))
#define GPIOA_CRH		( * ((volatile unsigned long*) 0x40010804))
#define GPIOA_ODR		( * ((volatile unsigned long*) 0x4001080C))
#define GPIOB_CRL		( * ((volatile unsigned long*) 0x40010C00))
#define GPIOB_CRH		( * ((volatile unsigned long*) 0x40010C04))
#define GPIOB_ODR		( * ((volatile unsigned long*) 0x40010C0C))
#define GPIOC_CRL		( * ((volatile unsigned long*) 0x40011000))
#define GPIOC_CRH		( * ((volatile unsigned long*) 0x40011004))
#define GPIOC_ODR		( * ((volatile unsigned long*) 0x4001100C))
void Delay(void)
	volatile unsigned int i;
	for (i = 0;  i < 325000; i++)  //DELAY OF 1 SECOND
void SystemInit(void)
int main(void)
	RCC_APB2ENR |= 0x00000018;
    volatile unsigned short k;
	GPIOC_CRH &=0x11111111;
	GPIOC_CRL &=0x11111111;
	GPIOA_CRH &=0x11111111;
	GPIOB_CRH &=0x11111111;
	volatile unsigned int A =0x0000;
	volatile unsigned int B =0x8000;
	volatile unsigned int C =0x2000;
	volatile unsigned int D =0x0800;
	volatile unsigned int E =0x0200;
	volatile unsigned int F =0x0080;
	volatile unsigned int G =0x0020;
	volatile unsigned int H =0x0008;
	volatile unsigned int I =0x0002;
	 while(1)
		 for(k=1;k<17;k++)
			Delay();
			Delay();
			if(k>=1 && k<=4)
			  GPIOA_ODR =A;
			  GPIOB_ODR =A;
			 if(k==1)
				GPIOC_ODR =B;
			  else if(k==2)
				GPIOC_ODR =C;
			  else if(k==3)
				GPIOC_ODR =D;
			  else
			    GPIOC_ODR =E;
			 if(k>=5 && k<=8)
			  GPIOC_ODR =A;
			  GPIOB_ODR =A;
			  if(k==5)
				GPIOA_ODR =B;
			  else if(k==6)
				GPIOA_ODR =C;
			  else if(k==7)
				GPIOA_ODR =D;
			  else
			    GPIOA_ODR =E;
			 if(k>=9 && k<=12)
			  GPIOA_ODR =A;
			  GPIOB_ODR =A;
			  if(k==9)
				GPIOC_ODR =F;
			  else if(k==10)
				GPIOC_ODR =G;
			  else if(k==11)
				GPIOC_ODR =H;
			  else
			    GPIOC_ODR =I;
			 if(k>=13 && k<=16)
			  GPIOA_ODR =A;
			  GPIOC_ODR =A;
			  if(k==13)
				GPIOB_ODR =B;
			  else if(k==14)
				GPIOB_ODR =C;
			  else if(k==15)
				GPIOB_ODR =D;
			  else
			    GPIOB_ODR =E;
above file are main file below file r pwm
#include "main.h"
#include "PWM.h"
void PWM_Init(void)
	RCC_APB2ENR |= 0x00000804;	//enable clock to GPIO port A and Timer 1
	GPIOA_CRH &= 0xFFFFF000;	//clear previous config for port A pin 8,9,10
	GPIOA_CRH |= 0x00000999;	//config port A pin 8,9,10 as 10Mhz push pull alternate purpose output.
	TIM1_CR1 = 0x0080;
	TIM1_CNT = 0;
	TIM1_PSC = 7;
	TIM1_ARR = (20000-1);
	TIM1_CCMR1 = 0x6868;
	TIM1_CCMR2 = 0x0068;
	TIM1_CCER = 0x0111;
	TIM1_CCR1 = 1000;
	TIM1_CCR2 = 1000;
	TIM1_CCR3 = 1000;
	TIM1_EGR = 0x0001;
	TIM1_BDTR = 0x8000;
	TIM1_CR1 |= 1;
void PWM_Ch1_drive_motor(const uint16_t PERIOD)
	if((PERIOD>=10)&&(PERIOD<=19950))
	H	TIM1_CCR1 = PERIOD;
	else if(PERIOD<10)
		TIM1_CCR1=10;
	else
		TIM1_CCR1=19950;
help to pont out the mistake or changing the code....
you are getting any compilation error or code is not working on hardware.
I m using keil uversion .....point out the error.....
