license.dat error for maxplus2 baseline
weiwei2
Malaysia
maxplus2 license
i removed my xilinx foundation 3.1 and installed altera maxplus2 10.2 baseline,
i follow altera's instruction to get a new license , set the LM_LICENSE variable in win2k to point to my file
but upon starting up maxplus2, it shows
"network licensing error. license file c:\xilinx\license.dat is missing or corrupted
how to solve this? i don't know where to change this settings of leftover by xilinx
maxplus 2 lm_license_file
Hi there,
Even I had the similar problem as yours.
Try doing this again
visit www.altera.com
Click on the top right hand corner where it says Licensing information.
there apply for the license
When I did this I didnt even had to set my licnse file as LM LICENSE FILE
it whould work okay
Let me know if u still have problems.
license.dat registry
one way try the license.DAT in the respected folders. otherwise go in register and select the location where license.dat is present.
if both neither works again request the license from altera.
i installed this week, i had no problem
maxplus2 license.dat
negative
i tried that, it still points the license file to xilinx... and i don't know where is that
this license is for maxplus2 vesion
have u tried to give the exact location of the license file?
if yes then have you given the c drive no. (hard disk no.) of your hard disk?
if that doesn't work then don't know whats the thing causing problem
maxplus2
What operating system u running.
When u un-installed Xilinx.
Did u made sure that everything was removed no directory likeC:\Xilinx exists on ur computer..
The other thing was that Xilinx doesnt use a license file it uses a product ID number for registering and the installation of the software..so I dont know why u have the license.dat file in the first place for XIlinx.
Other thing I would recommend is that check in ur registry settings for windows by running regedit command see if u can see anything over there for problems
Besides that I would suggest once u do the entire procedure for the installation of the license check ur autoexec.bat file and see if over there it says something like SET LM_LICENSE_FILE="dIRECTION WHERE THE LICENSE.DAT" is
If not then try it
You must restart the computer for changes to take effect..
If problem still persists.. Let me know
license maxplus2
The way of how to set the licentse.dat is diffirent between Xilinx and @ltera. Xlinx needs to add some word like SET LM_LICENSE_FILE="dIRECTION WHERE THE LICENSE.DAT" in autoexec.bat .But @ltera do not do like that.When Muxplus started,by toolsbar->help->license setup,then select the Muxplus license.dat from the place where u store.
And I used Muxplus10.1 and Qu@rturs ever,not Muxplus2 10.2 baseline.
