Leds doesn't turn ON
Okada
Banned
Hi
I am monitoring 5 different signals which are pulses. I am testing in Proteus. I am using PIC12F1840 with 8MHz Internal Oscillator.
I have referred device datasheet and configured all registers properly. I see 10ms Timer2 Interrupt working by toggling a pin but Leds doesn't turn ON. Gate control is not used. I am using Timer1 as 16 bit counter. I read pulses at T1CKI pin for 100ms and then calculate frequency (for 1 sec).
Here is my code.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
#define BRAKE_FREQUENCY_MIN    2110
#define BRAKE_FREQUENCY_MAX    2130
#define RH_FREQUENCY_MIN       1400
#define RH_FREQUENCY_MAX       1420
#define LH_FREQUENCY_MIN        990
#define LH_FREQUENCY_MAX       1010
#define BRAKE_RH_FREQUENCY_MIN  840
#define BRAKE_RH_FREQUENCY_MAX  860
#define BRAKE_LH_FREQUENCY_MIN  670
#define BRAKE_LH_FREQUENCY_MAX  690
#define OFF 0
#define ON  1
#define HUNDRED_MILLI_SECONDS_TIMER_TICKS_VALUE  10
sbit Red_led at   LATA0_bit;
sbit Green_led at LATA1_bit;
sbit Blue_led at  LATA2_bit;
sbit Test_Signal at LATA4_bit;
unsigned char my_flags = 0;
unsigned timer_ticks = 0;
unsigned int frequency = 0;
sbit reading_complete_flag at my_flags.B0;
//Timer2
//Prescaler 1:16; Postscaler 1:5; TMR2 Preload = 250; Actual Interrupt Time : 10.0025 ms
//Place/Copy this part in declaration section
void InitTimer2() {
    T2CON = 0x26;
    PR2        = 250;
    TMR2IE_bit = 1;
void Interrupt() {
    if(TMR1IF_bit) {
         ++frequency;      //not required as frequency read is less than 3KHz
         TMR1IF_bit = 0;
    if((TMR2IE_bit) && (TMR2IF_bit)) {
        //Enter your code here
        if(++timer_ticks == HUNDRED_MILLI_SECONDS_TIMER_TICKS_VALUE) {
            TMR1ON_bit = 0;
            TMR2IE_bit = 0;
            timer_ticks = 0;
            Test_Signal = ~Test_Signal;
            reading_complete_flag = 1;
        TMR2IF_bit = 0;
void Start_Reading_Input_Signal() {
    Test_Signal = 0;
    T1GCON = 0x00;
    InitTimer2();
    TMR1H = 0;
    TMR1L = 0;
    TMR1IE_bit = 1;
    T1CON = 0x85;
    PEIE_bit = 1;
    GIE_bit = 1;
void main() {
    OSCCON = 0x73;
    OSCSTAT = 0x99;
    OSCTUNE = 0x00;
    asm clrwdt
    OPTION_REG = 0x8F;
    CM1CON0 = 0x00;
    ANSELA = 0x00;
    TRISA = 0x20;
    PORTA = 0x00;
    LATA = 0x00;
    Delay_ms(100);
    reading_complete_flag = 0;
    Start_Reading_Input_Signal();
    while(1) {
          asm clrwdt
          if(reading_complete_flag) {
              //frequency = ((frequency << 16) + (TMR1H << 8) + TMR1L) * 10;//
              frequency = ((TMR1H << 8) + TMR1L) * 10;
              if((frequency > BRAKE_FREQUENCY_MIN) && (frequency < BRAKE_FREQUENCY_MAX)) {
                   Red_Led = ON;
                   Green_Led = OFF;
                   Blue_Led = OFF;
              else if((frequency > RH_FREQUENCY_MIN) && (frequency < RH_FREQUENCY_MAX)) {
                   Red_Led = OFF;
                   Green_Led = ON;
                   Blue_Led = OFF;
              else if((frequency > LH_FREQUENCY_MIN) && (frequency < LH_FREQUENCY_MAX)) {
                   Red_Led = OFF;
                   Green_Led = OFF;
                   Blue_Led = ON;
              else if((frequency > BRAKE_RH_FREQUENCY_MIN) && (frequency < BRAKE_RH_FREQUENCY_MAX)) {
                   Red_Led = ON;
                   Green_Led = ON;
                   Blue_Led = OFF;
              else if((frequency > BRAKE_LH_FREQUENCY_MIN) && (frequency < BRAKE_LH_FREQUENCY_MAX)) {
                   Red_Led = ON;
                   Green_Led = OFF;
                   Blue_Led = ON;
              frequency = 0;
  • Automobile Signals Monitor.rar
hello,
10mS every 1 second ?
duty ratio is to low to see anything ...
or maybe i didn't understund your problem ..
@paulfjujo
Thanks for replying.
100ms once every 1sec frequency of pulses is counted.
Timer2 is configured to interrupt once every 10ms.
Timer1 is configured as 16-bit counter
Timer1 Counter and Timer2 are started at the same time.
In timer2 ISR a variable is incremented 10 times (100ms) and then Timer2 and Timer1 Counters are stopped.
Timer1 result is multiplied by 10 (because we counted pulses for 100ms)
Frequency is displayed.
I am only writing the code. I don't have the hardware. They say that pulses of frequencies mentioned in the code are transmitted wirelessley using 27 MHz carrier frequency. The signal is received and fed to PIC. I don't know whether they are removing carrier frequency or not.
  • Automobile Signals Monitor - LCD Version.rar
  • Automobile Signals Monitor - Led Version.rar
hello,
i will have a look on your code .. and test it .
Timer is capable to count 27MHz ! (maxima is <50MHz) but i think you must have a demodulateur ( FM or AM)
to treat only the modulated signal and not the carrier frequency .
you can also add a RC filter Low band pass to reject H.F.
it seems you range of frequency to measure is from 670 to 2130 hz ?
to be continued ..
Yes, it is mentioned in the #defines.
Find attached project and Proteus Simulation. I ported the code to PIC18F26K22 just to confirm whether code is correct or not and it worked fine. Leds work and Lcd displays proper frequency but fluctuates a little. Have to test it on hardware.
Ok. I will design Low Pass RC filter to reject high frequency and allow only modulated signal to reach PIC.
Also attached Proteus Simulation Video for those who don't have Proteus. It shows Leds working.
I guess there is some problem with Proteus PIC12F1840 model related to timer or counter.
  • Automobile Signals Monitor - LCD Version - PIC18F26K22 - Revision C.rar
  • Proteus Simulation Video #2.rar
hello,
i tested 12F1840 version ..
they are some problems due to the use of same pin for Leds and I2C ....
I don't have Proteus , so i didn't see your schematic wiring.
i put Green led on RA4 output
Timer input on RA5
Frequency measure is OK .. when waiting flag in a while loop ..
else it is erratic .. maybe because too much timer2 interrupt .. i think you can use tmr0 instead to build 100mS time window
i tested the commutation of led, depending of Frequency value like in this example .
activate #define Test_Leds
but blue led can't be OFF , because I2C dialogue ..
I think you need a MCU with more Output .. to completly separate Led and I2C function.
// remove comment for test leds ,instead Freq meausre
//  #define Test_Leds          //
#define _LCD_FIRST_ROW          0x80     //Move cursor to the 1st row
#define _LCD_SECOND_ROW         0xC0     //Move cursor to the 2nd row
#define _LCD_THIRD_ROW          0x94     //Move cursor to the 3rd row
#define _LCD_FOURTH_ROW         0xD4     //Move cursor to the 4th row
#define _LCD_CLEAR              0x01     //Clear display
#define _LCD_RETURN_HOME        0x02     //Return cursor to home position, returns a shifted display to
                                         //its original position. Display data RAM is unaffected.
#define _LCD_CURSOR_OFF         0x0C     //Turn off cursor
#define _LCD_UNDERLINE_ON       0x0E     //Underline cursor on
#define _LCD_BLINK_CURSOR_ON    0x0F     //Blink cursor on
#define _LCD_MOVE_CURSOR_LEFT   0x10     //Move cursor left without changing display data RAM
#define _LCD_MOVE_CURSOR_RIGHT  0x14     //Move cursor right without changing display data RAM
#define _LCD_TURN_ON            0x0C     //Turn Lcd display on
#define _LCD_TURN_OFF           0x08     //Turn Lcd display off
#define _LCD_SHIFT_LEFT         0x18     //Shift display left without changing display data RAM
#define _LCD_SHIFT_RIGHT        0x1E     //Shift display right without changing display data RAM
#define LCD_ADDR 0x4E
#define OFF 0
#define ON  1
#define TEN_TIMES_TIMER2_TICKS_VALUE  10
 HARDWARE
 Pin 1     +VCC 5V
 Pin 2 RA5 ---T1G Timer1
 Pin 3
 Pin 4 RA2
 Pin 4 RA3 VPP  --390-----  VPP ICSP
 Pin 5 RA2 ----- 390 --- Led --
 Pin 5 RA2 ----- I2C SDA -------  LCD
 Pin 6 RA1 ----- I2C SCL  ------  LCD
 Pin 6 RA1 ----- 390 --- Led --
 Pin 6 RA1 ------  jaune ---- ICSP Data
 Pin 7 RA0 ----- 390 --- Led --
 Pin 7 RA0 ------- vert ----- ICSP  Clock
 Pin 8    0V Gnd  --------ICSP Gnd
sbit Red_Led at   LATA0_bit;
sbit Green_Led at LATA4_bit;
sbit Blue_Led at  LATA2_bit;
sbit Test_Signal at PORTA.B3;
sbit Red_Led_Direction at   TRISA.B0;
sbit Green_Led_Direction at TRISA.B4;
sbit Blue_Led_Direction at  TRISA.B2;
sbit Test_Signal_Direction at TRISA.B3;
const unsigned char Efface[]="                    "; // 20 spaces
char txt1[] = "Frequency:";
char txt[21];
unsigned char CRam1[21];
unsigned int i,j,k;
volatile unsigned timer_ticks = 0;
long Timer1_Overflow;
unsigned previous_frequency = 3000;
volatile int Time_Elapsed;
unsigned int Test_Leds_Values[]={2120,1410,1000,680};
  void Interrupts() iv 0x0004 ics ICS_AUTO
    if((TMR1IE_bit)&& (TMR1IF_bit))
     Timer1_Overflow=Timer1_Overflow+65536;
       //  ++frequency;      //not required as frequency read is less than 3KHz
         TMR1IF_bit = 0;
    if((TMR2IE_bit) && (TMR2IF_bit) )
        if(++timer_ticks >= TEN_TIMES_TIMER2_TICKS_VALUE )
            TMR1ON_bit = 0;
            TMR1IF_bit = 0;
            TMR2IE_bit = 0;
            TMR1IE_bit=0;
            timer_ticks = 0;
            //Test_Signal = ~Test_Signal;
           //reading_complete_flag = 1;
            Time_Elapsed=1;
            GIE_bit=0;
        TMR2IF_bit = 0;
//Timer2
void InitTimer2() {
    T2CON = 0x26;
    PR2 = 250;
     timer_ticks=0;
    TMR2IF_bit=0;
    TMR2IE_bit = 1;
     T1CON=0;
  //  Test_Signal = 0;
    T1GCON=0; //T1GSS<1:0>: Timer1 Gate Source Select bits  00 = Timer1 Gate pin
    Timer1_Overflow=0;
    TMR1H = 0;
    TMR1L = 0;
     Time_Elapsed=0;
    //bit 7-6 10 =Timer1 clock source is pin or oscillator:
    // bit 5-4 T1CKPS<1:0>: Timer1 Input Clock Prescale Select bits  00 => 1:1 Prescale value
    // bit 3 T1OSCEN: LP Oscillator Enable Control bit   0 = Dedicated Timer1 oscillator circuit disabled
    //bit 2 T1SYNC: Timer1 External Clock Input TMR1CS<1:0> = 1X
    //1 0 0 External Clocking on T1CKI Pin
    //  bit 8=1 and b2=1 = Do not synchronize external clock input
    //bit 0 TMR1ON: Timer1 On bit1 1= Enables Timer1
    T1CON = 0x85;
    InitTimer2();
    TMR1IE_bit = 1;
    PEIE_bit = 1;
    GIE_bit = 1;
void I2C_LCD_Cmd(char out_char) {
    char hi_n, lo_n;
    char rs = 0x00;
    hi_n = out_char & 0xF0;
    lo_n = (out_char << 4) & 0xF0;
    I2C1_Start();
    I2C1_Is_Idle();
    I2C1_Wr(LCD_ADDR);
    I2C1_Is_Idle();
    I2C1_Wr(hi_n | rs | 0x04 | 0x08);
    I2C1_Is_Idle();
    Delay_us(50);
    I2C1_Wr(hi_n | rs | 0x00 | 0x08);
    I2C1_Is_Idle();
    Delay_us(100);
    I2C1_Wr(lo_n | rs | 0x04 | 0x08);
    I2C1_Is_Idle();
    Delay_us(50);
    I2C1_Wr(lo_n | rs | 0x00 | 0x08);
    I2C1_Is_Idle();
    I2C1_Stop();
    if(out_char == 0x01)Delay_ms(2);
void I2C_LCD_Chr(char row, char column, char out_char) {
    char hi_n, lo_n;
    char rs = 0x01;
    switch(row){
        case 1:
        I2C_LCD_Cmd(0x80 + (column - 1));
        break;
        case 2:
        I2C_LCD_Cmd(0xC0 + (column - 1));
        break;
        case 3:
        I2C_LCD_Cmd(0x94 + (column - 1));
        break;
        case 4:
        I2C_LCD_Cmd(0xD4 + (column - 1));
        break;
    I2C1_Start();
    I2C1_Is_Idle();
    I2C1_Wr(LCD_ADDR);
    I2C1_Is_Idle();
    I2C1_Is_Idle();
    Delay_us(50);
    I2C1_Is_Idle();
    Delay_us(100);
    I2C1_Is_Idle();
    Delay_us(50);
    I2C1_Is_Idle();
    I2C1_Stop();
void I2C_LCD_Chr_Cp(char out_char) {
    char hi_n, lo_n;
    char rs = 0x01;
    I2C1_Start();
    I2C1_Is_Idle();
    I2C1_Wr(LCD_ADDR);
    I2C1_Is_Idle();
    I2C1_Is_Idle();
    Delay_us(50);
    I2C1_Is_Idle();
    Delay_us(100);
    I2C1_Is_Idle();
    Delay_us(50);
    I2C1_Is_Idle();
    I2C1_Stop();
void I2C_LCD_Init() {
    char rs = 0x00;
    I2C1_Start();
    I2C1_Is_Idle();
    I2C1_Wr(LCD_ADDR);
    I2C1_Is_Idle();
    Delay_ms(100);
    I2C1_Wr(0x30 | rs | 0x04 | 0x08);
    I2C1_Is_Idle();
    Delay_us(50);
    I2C1_Wr(0x30 | rs | 0x00 | 0x08);
    I2C1_Is_Idle();
    Delay_ms(10);
    I2C1_Is_Idle();
    Delay_us(50);
    I2C1_Is_Idle();
    Delay_ms(10);
    I2C1_Is_Idle();
    Delay_us(50);
    I2C1_Is_Idle();
    Delay_ms(10);
    I2C1_Wr(0x20 | rs | 0x04 | 0x08);
    I2C1_Is_Idle();
    Delay_us(50);
    I2C1_Wr(0x20 | rs | 0x00 | 0x08);
    I2C1_Is_Idle();
    I2C1_Stop();
    Delay_ms(10);
    I2C_LCD_Cmd(0x28);
    I2C_LCD_Cmd(0x06);
void I2C_LCD_Out(char row, char col, char *text) {
    while(*text) {
         I2C_LCD_Chr(row, col++, *text++);
void I2C_LCD_Out_Cp(char *text) {
    while(*text) {
         I2C_LCD_Chr_Cp(*text++);
 void I2C_LCD__CLS()
     I2C_LCD_Cmd(0x80);
     I2C_LCD_Out(1,1,(const char *) Efface );
     I2C_LCD_Cmd(0x80);
 void StrConstRamCopy(char *dest, const char *source) {
  while(*source) *dest++ = *source++ ;
  *dest = 0 ;    // terminateur
void main() {
    OSCCON = 0x70;    //      No PLL 8MHz
    // OSCSTAT = 0x99;   // read only !
    OSCTUNE = 0x00;
   // WUPEN =1 Pull up disable  PSA=1 Prescaler NOT for Timer0   Prescaler 1/256
  // OPTION_REG = 0x8F;
  CM1CON0=0;       // disable comparators
  CM1CON1=0;
   PORTA = 0x00;
    ANSELA = 0x00;
    TRISA = 0b00101000; //  RA4 output  , RA5 as TMR1 input ,RA3 = Pin MCLR used as input
    Red_Led_Direction=0;//RA0;
    Green_Led_Direction=0;//RA4
    Blue_Led_Direction=0; //RA2;
    Test_Signal_Direction=1;// RA3=MCLR
    Green_Led=0;
    Blue_Led=0;
    Red_Led=0;
    Delay_ms(2000);
    I2C1_Init(100000);
    I2C_LCD_Init();
    I2C_LCD_Cmd(_LCD_CURSOR_OFF);
    I2C_LCD_Cmd(_LCD_CLEAR);
    I2C_LCD__CLS();
    Delay_ms(1000);
    I2C_LCD_Out(1,1,txt1);
    Delay_ms(1000);
    i=0;
  //  reading_complete_flag = 0;
                    //12345678901234567890
     #ifdef Test_Leds
     I2C_LCD_Out(4,1,"Zone Test Led:      ");
     #else
    I2C_LCD_Out(4,1,"Indice :            ");
    #endif
    while(1)
    #ifdef Test_Leds
     for (j=0;j<4;j++)
      frequency=Test_Leds_Values[j];
     #endif
          while(Time_Elapsed==0);
           #ifdef Test_Leds
          WordToStr(j+1,CRam1);
          I2C_LCD_Out(4,14,CRam1);
          #else
            WordToStr(i,CRam1);
            I2C_LCD_Out(4,10,CRam1);
          #endif
          i++;
           if(Timer1_Overflow>0)
                //frequency = ((frequency << 16) + (TMR1H << 8) + TMR1L) * 10; <- integer over range !!//
               I2C_LCD_Out(2,1,"Over Range Timer1");
               Timer1_Overflow=0;
              else
              frequency = ( (TMR1H << 8) + TMR1L) * 10;
              WordToStr(frequency,CRam1);
              StrConstRamCopy(txt,"Frequency :       Hz");
              memcpy(txt+12,CRam1,5);
              I2C_LCD_Out(1,1,txt);
             #ifndef Test_Leds
               if(previous_frequency != frequency)
               #endif
                 // BRAKE_FREQUENCY_MIN    2110     BRAKE_FREQUENCY_MAX    2130
                       Red_Led = ON;
                       Green_Led = OFF;
                       Blue_Led = OFF;
                  //RH_FREQUENCY_MIN       1400      RH_FREQUENCY_MAX       1420
                       Red_Led = OFF;
                       Green_Led = ON;
                       Blue_Led = OFF;
                  //   LH_FREQUENCY_MIN        990    LH_FREQUENCY_MAX       1010
                       Red_Led = OFF;
                       Green_Led = OFF;
                       Blue_Led = ON;
                  //BRAKE_RH_FREQUENCY_MIN  840    BRAKE_RH_FREQUENCY_MAX  860
                       Red_Led = ON;
                       Green_Led = ON;
                       Blue_Led = OFF;
                  // BRAKE_LH_FREQUENCY_MIN  670   BRAKE_LH_FREQUENCY_MAX  690
                       Red_Led = ON;
                       Green_Led = OFF;
                       Blue_Led = ON;
                 previous_frequency = frequency;
                  //frequency = 0;   // ???
               #ifdef Test_Leds
                 Delay_ms(8000); // enough time to see LEDs changes
               } // for (i
              #else
          #endif
nota: RA3 can't be an output..
@paulfjujo
I am using LCD only for testing purpose. It will not be used in the final design. Only Leds will be used in the final design. Just to check if frequency reading is ok or not I used Lcd. I can't use Timer0 for 100 ms Interrupt because I have enabled WDT in OPTION_REG. Prescaler is assigned to WDT.
