Puppet123
Full Member level 6
Hello,
I would like to plot Iload vs. Vout for the Line Regulation for an LDO in Cadence Virtuoso and am wondering what the best approach would be.
I can put just an ideal current source, Idc using AnalogLib as the Load but that doesnt seem correct.
Should I use a controlled source in Cadence instead, like a current or voltage controlled source that links the two - if so - how would that be set up ?
Thank you.
Thank you.
