Layer Density Rules_Thermal Conductivity
MohsenS
Hello Everybody
I need some information about layout density rules. I want min and max density of different layers.
You might say that it depends on process. But a typical number is required. like numbers in a common process.
Also, I need information about thermal conductivity of materials used in different layers.
Thanks a lot.
They all varies from process to process .. It is adviced to get those inform from design rule document(DRD).
thanks. I googled for some DRD, but didn't find any useful document. can u link or attach an example ?
Density rules are based on the particular foundry's litho
capabilities.
Thermal conductivity, I just Google for and pull off whatever
site coughs it up first. But those constants are only part of
the picture, the layer thicknesses are another foundry-
specific bit of information.
capabilities.
i have some information about layer thicknesses.
but thermal conductivity and density ...
usualy poly density is about 15% per die area and metal about 30% - and higher. For min max you really have to pull out the process rules.
Have you any reference ? paper, report or so.
Here's an example for a 0.18µm 5M1P process:
