Laser diode driver - help or information needed
Amschel
Newbie level 1
Laser diode driver
Hi everyone!
I need some help/information to design an laser diode driver. I have been searching for the state of the art, but all I have found seems to me to be old-fashioned. For example in IEEE the papers I have found are all before 1985!
The laser diodes need to be fed with short current pulses (1 microsec.)
I want to desing it in the simplest way, so I was thinking about a bunch of bipolars. Any ideas?
Thanks in advanced.
Amschel
Hi
try this links :
h**p://students.washington.edu/zehekel/projects/ee332/ldd.pdf
h**p://pdfserv.maxim-ic.com/arpdf/AppNotes/3hfdn180.pdf
h**p://w*w.g0mrf.freeserve.co.uk/laser4.htm
I think that the best is use integrated drivers,
serch AD, ON SEMI, ROHM....
They exist up to 1Gbps if I know. And have integrated feedback.
I used before some time: MC10SX1130 and SLD202 diode
pool_77
help
Hi Friend
May be this will help full for you
Regards
Fragrance
8O Hi, ceck this w*w.ichaus.com
By, igo64
Laser diode driver
thanks for help also me :)
Re: Laser diode driver
The threashould current varies a lot of with temperature.
like 25mA at 25C and 50mA at 50C.
Is there a curcuit that take care of the temperature?
use IC they have feedback to eliminate temp.... or two diode element (there is second used for feedback)
