kahlenberg
Junior Member level 3
Hello,
I have a Toshiba satellite U405D, the backlight of LCD screen does not work. Inverter works, I checked it. VGA output also works if I connect an external display. I have found out that LCD inverter doesn't get "display on" and "pwm" signals at all. I also checked the cable, it is also healthy. I have found schematic of mainboard and I suspect EC(KBC) (Winbond WPCE775LA0DG) chip on motherboard. The schematic is below:
https://www.s-manuals.com/pdf/motherboard/quanta/quanta_bu2_r1a_schematics.pdf
The chip is shown an on page 28. How can I be sure that this chip is damaged? I am asking this forum before buying a chip, because maybe the reason is different that I have thought.
What else can cause this problem?
Thanks.
Thanks.
