Isolate R37 from Equation
TXRX
Full Member level 2
I need to Isolate R37 from the attached Equation.
The Resistors and Vo, Vf,VCC need to be in the equation.
Any Solution?
Thanks,
Doron
R37 is a very important part of the circuit since it and R42 set the input voltage of the opamp, then since the opamp has a gain of 1 the output voltage of the opamp is also set to be the same as the input voltage.
try this:
apply voltage divider at the + input of the op amp V+ = ...
assuming a perfect op amp, V- and output = V+
combine R25 and R28 to one equivalent resistor
assuming Vo is open, apply voltage divider (Vf, R21, V+ and equivalent R25-R28)
when you have Vo = ..., replace V+ with what you got above
follow the rules of algebra
expand everything so there are no parenthesis and no fractions
put all terms with R37 on one side of =, everything else on the other side
factor out R37 and divide
