is it possible to install orcad 9.1 and cadence 16.3 in same system?
m_kavith
Member level 3
chennai
i'm working in orcad 9.1.now i want install cadence 16.3 in same system.
after installation, i want to work in both the tool. is it possible or not?.
i need installation guide for cadence16.3?
what is cadence 16.3 shooter?
Yes. You should be.
Just curious, why do you need both? may be one can suggest a better solution.
I was wondering what is actually difference between two?
OrCAD is from company Cadence that's I am sure!
then what exactly is this Cadence 16.3 or whatever?
i basically did the same thing, installed both OrCAD 9.2 and OrCAD 16.0
why? because for schematics i designed using v16. then for simple auto-route i used v9.2. then i will use GerbTool from v16 to insert logo and modify certain things such as changing the Holes of DC Jack into Slots.
seems like i learned how to use SPECCTRA, i could just stick with v16. if anyone could share tips on how to use simple-single-click auto route like in v9.2 i would appreciate so much.
Thanks.
