Is a tantulum different from a microfarad tantulum cap?
riffwraith
Junior Member level 2
Or are they the same?
BTW - thanks for the help in my other thread! :thumbsup:
I am experimenting with modding my old school Marshall amp. I threw a cap in an otherwise unused slot. Why? B/c a very well-known and highly respected mod guy/amp builder did just that in one of his mod videos. So I figured, well if he did, I can do it! ;-)
Turns out that with the cap in place, I am having a slight problem with some noise, and some sound artifacts - neither of which were there before I added the cap, and neither are there after I removed it.
The cap I added was a .68k tantulum cap @35 volts. I went back and re-watched that portion of the vid, and I now hear him say that he added a .68k microferet tantulum cap @35 volts.
So, the Q is - are they the same thing, or is there a diff when you add microferet into the mix?
Thanks in advance.
Re: Is a tantulum different from a microferet tantulum cap?
I think you misheard. MICROFARAD, not “microferret”. And, there’s no such thing as a .68k cap. .68 microfarad, maybe? 68 microfarad?
Quite possibly!
Ok, should have typed .68uf - sorry!
Most likely you have a defective tantalum cap.
Where did you purchase it?
I am sure that you are aware that there are many sub-standard or counterfeit components out there, specially in places like Ebay or Alibaba
Tantalum is a type of electrolytic capacitor.
Microfarad is 1 millionth of a farad, which states the charge storage capacity of the capacitor.
From Mouser. Ordered three caps; tried two with the same result.
When an oriental capacitor is marked with "k" then it means its value is +/- 10% tolerance.
A tantalum capacitor has polarity. If you connected it backwards then it might be damaged and not work correctly.
Did Mouser send you capacitors or tiny little animals?
Yes. Tantalum is a metal, like Aluminium or Titanium. Tanatalum capacitor is a special kind of electrolytic (mostly solid; unlike aluminium electrolytic ones) capacitor that uses Ta (it is symbol of the element; like Al is the symbol for Aluminium).
The capacitor has two important specifications: max working voltage (35V in this case) and capacity (likely 68 microfarads) in your case.
Thanks for the nice visual. I have never met him before.
Both! I tried hooking up the ferrets first, but I found the sound too furry.
When an oriental capacitor is marked with "k" then it means its value is +/- 10% tolerance. A tantalum capacitor has polarity. If you connected it backwards then it might be damaged and not work correctly.
Thanks for that.
So, I have no idea where the cap was manu'd, but it does indeed have a 'k'; switching the polarity makes no difference. I have two; they both have given me the same result.
Thanks!
0.68uF is well within the range of 35V ceramic caps. But you
should never apply a capacitor at (or even near) its rated
voltage.
In an audio application where this cap might see a reversing
polarity, the asymmetric nature of most tantalum and electrolytic
caps could add some rectification, which makes distortion. Try
a nonpolar (like ceramic) if you know this to be the case, or
do not know what the case is.
If you had a manufacturer's schematic (or one with total attention
to detail) it might have said whether the cap was polarized or to
be a nonpolar type.
Spiral wound capacitors can have a lot of inductance, which might
affect the frequency flatness. A cap made for filtering 120Hz ripple
is not necessarily up to snuff for a >kHz audio application.
