Is a phasor a vector?
powersys
Advanced Member level 1
A vector, as what I know, is a quantity that has magnitude and direction.
Is a phasor considered as a vector?
Thanks.
Phasor = Phase Vector
Amr Ali
    powersys
Thanks.
A phasor (phase vector) is a vector which rotates with the angle velocity ω. It is an abbreviation of exp(jωt).
    powersys
Thanks for your replies. If phasor is a vector, then pls help me in the following thread...
Generally, I think it is important to know the definitions of technical terms and to use them properly. However, perhaps in this case it is not too important if a rotating "object" which is a pure mathematical quantity having a constant magnitude and a changing phase (proportional to time) is called "vector" or "phasor".
As already mentioned, the inventor of the name "phasor" did consider this rotating object as a kind of vector. Other authors restrict the term "vector" to purely geometric objects.
For my opinion, more important is to know what this quantity means and how it is used in system theory.
    powersys
