hbklau
Newbie level 5
Hi all,
I have some queries over here and hope someone can enlighten me. I am using 6N135 optocoupler and the input to it is coming from a PWM. As per the datasheet, the output will be inverted. However, this is not what i want as I need the actual waveform (Similar to input) to operate a MOSFET for the DC converter. Is there any way to revert the output? I had drawn a connection diagram with a BJT connected at the output. Please advise whether will the output will be revert back?
Next, is it possible to connect a logic gate inverter to the output to just invert the waveform?
