Rakesh Menon
hi
I was working with interfacing of hc sr04 ultrasonic sensor with lpc1768 so as to display the distance from an obstacle to the sensor on an LCD display in centimeters ..
there were no errors in the code, but distance is not being varied its showing always as 0 cm..
i could not find the problem.. i'm sure that sensor is in good condition
i'm attaching the code
Microcontroller: LPC1768-Cortex M3
Clock: 12mhz
Compiler Keil uVision 4
Clock: 12mhz
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 #include "lpc17xx.h" #include "type.h" #include "delay.h" #include "lcd.h" //header file to program LCD #define US_PORTCLR LPC_GPIO0->FIOCLR #define US_PORTSET LPC_GPIO0->FIOSET #define US_DDR LPC_GPIO0->FIODIR #define US_PIN LPC_GPIO0->FIOPIN #define US_ECHO 5 // pot 0 5th pin for echo #define US_TRIG 6 // p0.6 for trigger #define US_ERROR 0xffff #define US_NO_OBSTACLE 0xfffe uint32_t d; uint16_t getPulseWidth() { uint32_t i,result; //Wait for the rising edge for(i=0;i<600000;i++) { if(!(US_PIN & (1<<US_ECHO))) continue; else break; } if(i==600000) return 0xffff; //Indicates time out //High Edge Found //Setup Timer1 LPC_SC->PCONP |= 1 << 1; //Power up Timer 0 LPC_SC->PCLKSEL0 |= ( 1 << 2)|(1<<3); // Clock for timer = CCLK /8 -->12000000/8hz LPC_TIM0->TC=0x00000000; // init counter LPC_TIM0->TCR |= 1 << 1; // reset timer LPC_TIM0->TCR |= 1 << 0; // Start timer //Now wait for the falling edge for(i=0;i<600000;i++) { if(US_PIN & (1<<US_ECHO)) { if((LPC_TIM0->TC) > 60000) break; else continue; } else break; } if(i==600000) return 0xffff; //Indicates time out //Falling edge found result=(LPC_TIM0->TC); //STORE COUNT IN RESULT //Stop Timer LPC_TIM0->TCR |= 0 << 0; if(result > 60000) return 0xfffe; //No obstacle else return (result>>1); } int main(void) { uint16_t r; LPC_PINCON->PINSEL0|=(0<<10)|(0<<11)|(0<<12)|(0<<13);// MAKING P0.5,6 AS GPIO SystemInit(); lcd_init(); //initialization of LCD delay(500); lcd_gotoxy(0,0); //function to move the cursor position to (0th row & 5th column ) lcd_string("Hc sr04 test"); //function to display a string delay(500); while(1) { //Set Ultra Sonic Port as out US_DDR|=(1<<US_TRIG); delay_us(10); //Give the US pin a 15us High Pulse US_PORTSET|=(1<<US_TRIG); //High delay_us(15); US_PORTCLR|=(1<<US_TRIG);//Low delay_us(20); //Now make the pin input US_DDR&=(~(1<<US_ECHO)); //Measure the width of pulse r=getPulseWidth(); //Handle Errors if(r==US_ERROR) { lcd_clear(); lcd_gotoxy(0,0); delay_us(100); lcd_string("error"); } else if(r==US_NO_OBSTACLE) { lcd_gotoxy(0,0); \ delay_us(100); lcd_string("clear"); } else { d=(r/58.0); //Convert to cm lcd_gotoxy(1,0); lcd_string("d="); delay_us(100); lcd_gotoxy(1,4); lcd_showvalue(d); delay_ms(50); lcd_gotoxy(1,7); lcd_string("cm"); delay_ms(100); } } }
