Interfacing PCI9054 in burst mode,need help!
janlee
Newbie level 5
pci9054
In my project I use PCI9054 "C Mode" to control FPGA and other peripherals.Acturally PCI9054 acts as local bus master and PCI target.
I successfully realize the signal cycle 32 bits read & write.But it quite slow,the interval between two continous read or write is more than 12 us.To control register in the FPGA is not a problem,but to transfer large block of data in real time it is not accecptable.
Now my question is how to configure the PCI9054 to lanch a burst transfer via PLX's funcions(I wonder which function I can use) ,and how to modify my code to adapt this transfer.
Many appreciations.
--Module      : PCI9054 interface Module
--File        : PCI9054_IF.vhd
--Library     : IEEE;
--Description : PCI9054 interface controller
--Simulator   : Modelsim 5.8/WindowsXP
--Synthesizer :
--Author      :
--Created     : 06/07/2006
--Last update : 25/07/2006
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity PCI9054_IF is
port(
      RST_N : in std_logic;
      LCLK : in std_logic;
      LHOLD : in std_logic;
      ADS_N : in std_logic;
      BLAST_N : in std_logic;
      LWDRD_N : in std_logic;
      LA : in std_logic_vector(31 downto 2);
      LD : inout std_logic_vector(31 downto 0);
      LHOLDA : out std_logic;
      READY_N : out std_logic;
      ACK_n : in std_logic;
      WR_n : out std_logic;
      RD_n : out std_logic
end PCI9054_IF;
architecture RTL of PCI9054_IF is
type STATE_TYPE is (IDLE,START,WAITSTATE,LAST);
signal CURRENT_STATE,NEXT_STATE : STATE_TYPE;
signal iready_n : std_logic;
signal iwr_n,ird_n : std_logic;
signal iaddr : std_logic_vector(31 downto 2);
begin
   --Grant for local bus request
   process(LCLK)
   begin
      if (LCLK'event and LCLK = '1') then
         if LHOLD = '1' then
            LHOLDA <= LHOLD;
         else
            LHOLDA <= '0';
         end if;
      end if;
   end process;
   --State Machine Transition
   process(LCLK)
   begin
      if RST_n = '0' then
         CURRENT_STATE <= IDLE;
      elsif(LCLK'event and LCLK = '1') then
         CURRENT_STATE <= NEXT_STATE;
         if CURRENT_STATE = IDLE and ADS_N = '0'then
            iaddr <= LA;
         end if;
         READY_n <= iready_n ;
      end if;
   end process;
   --State Machine
   process(CURRENT_STATE,ADS_N,LWDRD_N,BLAST_N,ACK_n)
   begin
      NEXT_STATE <= CURRENT_STATE;
      case CURRENT_STATE is
         when IDLE =>
            RD_n <= '1';
            WR_n <= '1';
            iready_n <= '1';
            if ADS_N = '0' then
               NEXT_STATE <= START;
            else
               NEXT_STATE <= IDLE;
            end if;
         when START =>
            RD_n <= '1';
            WR_n <= '1';
            iready_n <= '1';
            if BLAST_N = '0' then
               NEXT_STATE <= WAITSTATE;
            else
            end if;
         when WAITSTATE =>
            RD_n <= LWDRD_N;
            WR_n <= not LWDRD_N;
            if iaddr(31 downto 4) = B"0010_0000_0000_0000_1001_0000_0000"   then
               if ACK_n = '0' then
                  NEXT_STATE <= LAST;
                  iready_n <= '0';
               else
                  iready_n <= '1';
               end if;
            else
               NEXT_STATE <= LAST;
               iready_n <= '0';
            end if;
         when LAST =>
            RD_n <= '1';
            WR_n <= '1';
            iready_n <= '1';
            if ADS_N = '1' and BLAST_N = '1' then
               NEXT_STATE <= IDLE;
            elsif ADS_N = '0' then
            else
               NEXT_STATE <= LAST;
            end if;
         when others =>
            RD_n <= '1';
            WR_n <= '1';
            iready_n <= '1';
            NEXT_STATE <= IDLE;
      end case;
   end process;
end RTL;
pci 9054 problem
I think that 12us for a single rd/wr cycle is too much. I'm worked few years ago with PCI9054 and this acces time was about 100ns (i'm configured this time to 100ns for proper acces to local SRAM).
I think that your PCI9054 are not configured properly.
From your vhd code I understood that your PCI9054 act as PCI master. Can you tell me which timing diagrams (from databook) are used to implement the vhd code?
how to access the pci9054 using fpga
Thanks for ur replay! :D
U may misunderstand that I said the intervals of continous read or write cycle is 12us,rather than the singal read or write cycle itself . The singal cycle is quite fast it consumes 4~5 LCLK,I wonder what the OP system do when in the interval of continous singal read and write cycle.
Please help me!
pci9054 local bus+timing diagram
The 12us delay even between rd/wr cycles is too much.
What are the value of LCLK? And PCI to local registers are proper configured?
Anyway, i suggest to assert iready_n signal on the following clock after ADS_N signal is asserted (if your FPGA can accept data)
plx write main configuration registers
The LCLK is 25MHz,I do assert Ready_n after ADS_n,but I use address to differenciate the 2 peripherals(FPGA's registers and ADV611).FPGA's internal registers doesn't have ACK_n,ADV611 has its ACK_n.
I wonder PLX's functions is the only way to configure PCI9054 into burst mode.But I didn't know how to do .
pci9054 local control signal timing diagram
You can use the same PLX functions to read all PLX registers. You should control this registers for proper PLX operation. Maybe your PLX registers are not configured to use READY# signal...
The next quote is from data book:
If READY# mode is disabled, the external READY#
input signal has no effect on wait states for a Local
access. Wait states between Data cycles are asserted
internally by a wait state counter. The wait state
counter is initialized with its Configuration register
value at the start of each data access.
If READY# mode is enabled, it has no effect until the
wait state counter reaches 0. READY# then controls
the number of additional wait states.
BTERM# input is not sampled until the wait state
counter reaches 0. BTERM# overrides READY# when
BTERM# is enabled and asserted.
Did you finally have it working?
Can you post your code please.
I'm trying to interface with PLX 9056
Re: pci9054
I'm trying to interface with PLX 9054
my email is m.tajalipour@gmail.com
please help.
thanks.
So do I
I am working in interface with a pci 9030. I studied the project a few months ago, and I need help to continue.
Please if someone like to work together or someone have some information i would be very grateful.
contact us jcastillo@rfranco.com
