Interfacing keyboard to microcontroller
Drew
keyboard microcontroller
I'm having a problem getting my 5 pin keyboard to interface to my microcontroller. I have the Vcc and GND lines connected to 5V and ground. I'm using an oscilloscope to read the Data and Clock lines but come up short. Even when I'm holding a key down continuously, the oscilloscope doesn't pick up any signals. Do the DATA and Clock lines have to be connected to 5V through external pull up resistors? I thought keyboards had internal pull up resistors. Thanks for any responses.
interfacing keyboard to 8051
It is possible that there are no pull-ups inside the keyboard, so you can easily connect ≈4.7kΩ as pull-ups.
What happens when you apply power to the keyboard, do the 3 LEDs flash a couple of times as normal?
interfacing keyboard with 8051
The lights don't flash after power up. However, it does work when plugging it into a motherboard. When I press a key continuously should I see signals on the Data and Clocks lines using the oscilloscope? I've tried this test on 3 keyboards already, coming up short each time.
keyboard interfacing with 8051
The keyboard should perform a RESET on startup, and this should be visible by looking at the LEDs, they should blink briefly. Check your electrical connections. Also be aware that the KB may need well above 100mA to function properly, so check if your power source meets this requirement.
keyboard with microcontroller
Make sure you connect power (+5V and 0V) correctly: it should flash after power is applied.
Both lines, clock and data, are HIGH at the idle stage. When you press a button you should see pulses from High/Low/High ..
Are we talking about the same keyboards: PS/2 .. AT?
interfacing keyboard to microcontroller
My bad. The three LED lights DO flash after power up. The Data and Clock lines are held high at 5 V and remain there even when pressing on a key continuously. I'm using an AT keyboard.
interfacing keyboard with microcontroller
This is strange. Is the keyboard connected to a microcontroller which I/O pins force the data and/or clock lines to logical 1, by any chance?
related:electrosofts.com/8051/keyboard.html
The data and clocks lines are connected to 5V through 5 Kohm external pullups. and to the oscilloscope. There are no connections to the microcontroller. Do I have to give it a permission-to-send command?
microcontroller keyboard
No, it needs no special permissions, both clock and data are idle. Very weird. Check your oscilloscope settings.
keyboard interfacing with 8051 microcontroller
Maybe this application note is useful for you.
keyboard interfacing to 8051
does anybody have some similar code in pic basic pro???
interfacing of keyboard with 8051
Is the keyboard connected to a microcontroller? then force the data and/or clock to pull up.
interfacing keyboard microcontroller
hi,
if u send the electric diagram it will be much more easy to help u.
r u using bi-directional communication or uni ?? make sure that the microcontroller's control pins are configured as input when using uni direction (in my opinion keyboard-host is enough).
one more thing the ideal state is reached automatically by using the pull up resistors, the micro controller should not force there "1" !!!
avi.
