arghpok
Member level 3
Hi all,
I'm working designing a buck or boost (not buck/boost) DC/DC converter, and I have problems regarding the inrush current. The maximum tolerable is 1A but I'm achieving 2+ when powered on. How can I implement a soft start without introducing more elements in the power path ?
I've seen resistors in series in the power path for the start-up that are short-circuited after the required voltage has been reached. However, that would need a HUGE switch in parallel with the resistor (In fact the resistor has to be huge as well to let 500mA pass during the turn-on), and that would introduce another dissipative element in the power path.
Is there some way to control one of the powerMOS of the converter as a "LDO" during the start-up and then changing it to the regular control trough the drivers ? With you could clamp the Vgs in the transistor so you limit the current passing though it by modulating the resistance. It sounds too good to be true and I haven't seen it yet. Anybody has experience with this kind of circuits ? or another solution for this problem ?
Thank you,
Thank you,
