Well, you can set the DCM's DUTY_CYCLE_CORRECTION attribute to true.
Refer to Virtex-5's user guide ug190 and search 'duty cycle correction' for more details.
Thanks philoman...
But the duty cycle correction works only for clk1x..i.e. clk0, clk90, clk270...but for clkfx it varies depend on M/D....i do not want to use one more dcm to generate clkfx using the output of first dcm..i want to know the tolerance for M/D values..
