INFRARED (WHICH ONE I SHOULD CHOSE?)
dumanmehmet
Newbie level 6
TURKEY
Hello forum,
I am researching the *IR sensors* that can work between -5 (*C) and 85 (*C).
i dont measure too long distance,** if it sense 3cm to 30cm clearly it is OK for me...
+++ but the temperature is very important. the heater it works, the better for us..
any knowledge that you have please reply my request...
thank you ....*
You could use TSOP173x(1738,1737, 1736, etc), which are among the most popular IR sensors. According to the datasheet, these devices will work over a temperature range of -25'C to 85'C.
Hope this helps.
Tahmid.
thx I can only found tsop 1136 in Turkey. one of the friend also said tsop 1838 but there isn't any.
regards.
I assume you need analogue analogue output, not digital. The TSOP1136 is digital.
Keith
