shaiko
Advanced Member level 5
I have a custom type that's defined as follows:
signal x is declared as follows:
signal x : unconstrained_array ;
I want to write a loop that assignes to x an array of incrementing unsigned numbers as follows:
"0000"
"0001"
"0010"
"1111"
However, becuse x is an unconstrained array, I want the code to be generic and except any width and depth of x.
This is what I wrote so far:
What do you think? Anything I should fix?
type unconstrained_array is array ( natural range <> ) of unsigned ;
"0000"
"0001"
"0010"
"1111"
for index in x ' range
loop
x ( index ) <= to_unsigned ( index , ( x ' length ) ) ;
end loop ;
