areeckal
Member level 2
I am posting my RF transmitter code:
While I debugged it in mplab , i got the following output from uart-i/o tab.
1701.
Whats the bug?
#include <htc.h>
#include "usart.h"
//Chip Settings
__CONFIG(1,0x0200);
__CONFIG(2,0X1E1F);
__CONFIG(3,0X8100);
__CONFIG(4,0X00C1);
__CONFIG(5,0XC00F);
void main()
unsigned int data,addr,synchro;
//Initialize the USART
USARTInit();
//TRISC=0xC0;
//Now Read some input
while(1)
data=0b00000001;
addr=0b00000000;
synchro=0b10101010;
Now send a Packet
Packet Format is AA<data><data inverse>Z
total Packet size if 5 bytes.
//SYNCHRO byte
USARTWriteInt(synchro,8);
_delay(100);
//Address
USARTWriteInt(addr,8);
_delay(100);
//Data
USARTWriteInt(data,8);
_delay(100);
//Checksum
USARTWriteInt(data+addr,8);
_delay(100);
//Stop bit
USARTWriteInt(0,8);
TXEN=0;
Most Basic USART (RS232 Serial) Communication Support File.
Simple reading and writing of data without using
Interrupts.
BAUD RATE:57600 Bits per Second
CRYSTAL Frequency: 20MHz
Target Chip: PIC18F4520
Target Compiler: HI-TECH C For PIC18 (http://www.htsoft.com/)
Project: MPLAP Project File
#include <htc.h>
#include<stdio.h>
#include "usart.h"
void USARTInit()
//Baud Rate = 57600 Bits per Second
//*** Note: Valid On 20MHz Crystal ONLY ***
//For other crystal freq calculate new values for SPBRG
SPBRG=86;
//TXSTA REG
TXEN=1;
BRGH=1;
//RCSTA
SPEN=1;
CREN=1; //Enable Receiver (RX)
//BAUDCON
BRG16=1;
void USARTWriteByte(char ch)
//Wait for TXREG Buffer to become available
while(!TXIF);
//Write data
TXREG=ch;
void USARTWriteString(const char *str)
while((*str)!='\0')
while(!TXIF);
//Write data
TXREG=(*str);
//Next goto char
str++;
Writes a line of text to USART and goes to new line
The new line is Windows style CR/LF pair.
This will work on Hyper Terminal Only NOT on Linux
void USARTWriteLine(const char *ln)
USARTWriteString(ln);
USARTWriteString("\r\n");
void USARTWriteInt(int val,unsigned char field_length)
if(val<0)
USARTWriteByte('-'); //Write '-' sign for negative numbers.
val=(val*(-1)); //Make it positive.
//Convert Number To String and pump over Tx Channel.
char str[5]={0,0,0,0,0};
int i=4,j=0;
while(val)
str[i]=val%10;
val=val/10;
i--;
if(field_length>5)
while(str[j]==0) j++;
else
j=5-field_length;
for(i=j;i<5;i++)
USARTWriteByte('0'+str[i]);
unsigned char USARTReadByte()
while(!RCIF); //Wait for a byte
return RCREG;
1701.
Whats the bug?
