dsk2858
Member level 2
- Joined
- Aug 17, 2011
- Messages
- 47
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Chennai,India
- Activity points
- 1,683
HI to all the forum members,
I designed a board with 8keys, as we all know that with the help of this 8keys we can produce 256 combinations.
i took few combinations and written code to generate ASCII values with respected those combinations which matches our standard PS-2 keyboard ASCII values.
FOR EXAMPLE
combination ASCII(HEX) KEYBOARD FUNCTION
00101011 41 A
00101100 42 B
00101101 43 C
10000000 09 TAB
10000001 0D ENTER
10000010 E2 WINDOWS
here i attached a video of it where i printed alphabets and numbers in hyper terminal window.
https://www.youtube.com/watch?v=nLH0l6dD7wA&feature=g-upl&context=G20dd7bcAUAAAAAAAAAA
but now i need to control my computer with the combination of this 8key board instead of standard ps-2 key board.
i connected the board to the computer through USB interface not RS232.
now i need to translate those ASCII CODE TO USB PC KEYBOARD functionality.
QUESTIONS?
Should i need any Hardware in between the board i designed and the PC.
OR should i need any software to be loaded on the PC so that it would convert the incoming ASCII value in to key board functionality so that i can control my PC (i.e., like when we connect a standard PS-2 OR USB based keyboards to our PC it asks for drivers).
AND with what baud rate should i transmit those ASCII values to the computer , for the above example i used 9600 baud rate.
FOR EXAMPLE
00101011 41 A
00101100 42 B
00101101 43 C
10000000 09 TAB
10000001 0D ENTER
10000010 E2 WINDOWS
QUESTIONS?
