kavkav
Junior Member level 1
Hi, I am new to circuits so please bare with me. I am trying to build something that gives off a specific sinusoidal frequency with high amplitude like an oscillator or an inverter. However I have attempted several different oscillators and ended up with failure. Either it didn't work or the oscillator only oscillated for a fraction of a second. Currently i am working on a quadrature oscillator with schematics from this website:
it is the diagram on the bottom right.
However when I built it, nothing happened. I checked the schemstic a hundred times and my circuit was correct. However there is one issue. I am not oto sure about the ground symbol. Is it the same as connecting all the ground symbols together then to the negative end of a battery? because i treid that and i connected the output to the positive end of the battery and used a tester to test it but it was not giving off sny frequency. I also tried reversing the output and input connection to the battery but still nothing. I the circuit with an output using a circuit simulator and it worked:
Circuit Simulator Applet
is the simulator wrong? I have no clue but i doubt it would be.
DETAILS
my DC battery: 6v 1.3Amps
my resistors: 10 Kohms
my capacitors: 2.2uf
my desired frequency: approx 7 hz
my op-amp: MC1741CP1 ZKQAG811 (then it has some M symbol below)
my second op-amp: LM741CN (then some ST symbol) 88916
my op amps look exactly like the one on this website:
The 741 Operational Amplifier
As a last note of detail, my capacitors 50v on them. I'm assuming this means it can handle up to 50v rather "only work with" 50v. so if someone could clarify that for me, thanks.
In general terms, I'm just trying to make something that gives a desired frequency of 7hz with high amplitude/current. If you know a better way or a simpler oscillator that will give me continuous oscillations PLEASE let me know. Also if you could clarify my question about the ground symbol that would be great. Or if you can figure out why my quadrature oscillator is not working that would also be greatly appreciated. Thanks.
DETAILS
