in 8051 we use port0 as I/O port or addressdata bus?
logukalipal
Junior Member level 2
Coimbatore, India
Hi..!
beginners voice: can we use port0 of 8051 as Input/Output port or AddressData port only?
If we can use both I/O port and AddrData port means, how i use?
Port 0: Port 0 occupies a total of 8 pins (pins 32-39) .It can be used for input or output. To use the pins of port 0 as both input and output ports, each pin must be connected externally to a 10K ohm pull-up resistor. This is due to the fact that P0 is an open drain, unlike P1, P2, and P3.Open drain is a term used for MOS chips in the same way that open collector is used for TTL chips. With external pull-up resistors connected upon reset, port 0 is configured as an output port. For example, the following code will continuously send out to port 0 the alternating values 55H and AAH
Dual role of port 0: Port 0 is also designated as AD0-AD7, allowing it to be used for both address and data. When connecting an 8051/31 to an external memory, port 0 provides both address and data. The 8051 multiplexes address and data through port 0 to save pins. ALE indicates if P0 has address or data. When ALE = 0, it provides data D0-D7, but when ALE =1 it has address and data with the help of a 74LS373 latch.
Thanks a lot...
Now my question is, In 8051 can i use port0 as both I/O and Addressdata port using any method?
(i.e)Now i interfaced the external memory so am used port0 as addr data port using latch. now i need a I/O port, so i ask using any technic we use the same port0 as I/O port?
[OR]
We use only port0 as In/Out port else Addressdata port?
Thanks in advance..
learn from here
Read this free online book :
Architecture and programming of 8051 MCU's
Author: Milan Verle
https://www.mikroe.com/products/view/267/architecture-and-programming-of-8051-mcu-s/
Specially this chapter :
2.3 Input/Output Ports (I/O Ports)
:wink:
Thanks a lot..
Ans is:
Port-0 can be configured as a normal bidirectional I/O port or it can be used for address/data interfacing for accessing external memory. When control is '1', the port is used for address/data interfacing. When the control is '0', the port can be used as a normal bidirectional I/O port.
Thanks a lot..
Ans is:
