ic5 cd3 install and some questions
wxsimon
Junior Member level 2
China
ic5 cd3
What is ic5 cd3? I remebered that it had been asked before in the forum, I searched, but nothing found :cry:
And how to install it? For linux?
Are there some design kits available?
Thanks in advance.
Re: ic5 cd3
Thanks in advance.
For linux release,it has only two cd
IC5 CD3 is for Solaris version only. There are only 2 CDs for Linux Baseline product.
Linux has the ISR CD, is this CD your IC5 CD3?
It is for solaris8 and newer version.
all media are 3 cd
Re: ic5 cd3
Hello,
when i start with icfb the program comes up and in the ciw the following messages appear:
8-bit PseudoColor Visual is not available (default Visual option).
\o Using 24-bit TrueColor Visual.
\o The program xdpyinfo can be used to verify the Visuals available
\o for your display.
\o Loading PRshare.cxt
\o Loading LVS.cxt
\o Loading acv.cxt
\o Loading auCore.cxt
\o Loading schView.cxt
\o Loading selectSv.cxt
\o Loading seismic.cxt
\p >
\o Warning: Cannot convert string "-adobe-helvetica-medium-r-normal--0-100-75-75-p-0-iso8859-1" to type FontStruct
\o *Error* getqq: argument #1 should be a symbol (type template = "sS") - (cdba.data)
\o Loading Skill files for skillCore
\o *WARNING* (autoloads): skillCore.cxt was not loaded
\o *Error* load: can't access file - "startup.il"
\o ******* Non-recoverable error (no top-level or error handler)
\o ******* Exiting program ...
The porgram though doesn't exit, I cannot see anything in a cell in layoutplus.
can someone help me?
Re: ic5 cd3
May be 3d CD is a Hotfix?
