IC5.0.0 run LVS in diva ,netlist is bad! please help me!
demi91
netlist as follow:
layout netlist:
n 0 /Z
n 1 /VDD
n 2 /A
n 3 /B
n 4 /6
n 5 /VSS
No element format property found for element /+5
No element format property found for element /+4
No element format property found for element /+3
No element format property found for element /+2
No element format property found for element /+1
No element format property found for element /+0
t 0 "Z" output
t 5 "VSS" input
t 1 "VDD" input
t 3 "B" input
t 2 "A" input
schematic netlist:
n 0 /VDD
n 1 /Z
n 2 /A
n 3 /B
n 4 /VSS
n 5 /net032
No element format property found for element /M2
No element format property found for element /M4
No element format property found for element /M5
No element format property found for element /M0
t 4 "VSS" input
t 0 "VDD" input
t 3 "B" input
t 1 "Z" output
t 2 "A" input
How should I do???
Re: IC5.0.0 run LVS in diva ,netlist is bad! please help m
Fix this in schematics
and layout too
How modify concretely?Please tell me! Thank you!
How modify in layout? Is turn schematic's cell lib to base's lib in IC5?
Do this schematic's netlist is bad too!
How should I do???
Is license file's problem?
ok! ok! ok! Thanks for your attention!!!
Look at the property of the problem element. What kind of device is that?
I guess it's atransistor, but it's not define well
Check your .simrc file.
It must contain uncommented "for transistor level comparision for analog artist" block. Other comparision blocks must be commented
Thanks a lot . I had solved this problem.
