IBIS model, XILINX, SPARTAN 3
cherukukeshav
Junior Member level 3
xilinx ibis
We are using xc3s400,fg456,-4 device with some pins declared with DCI option.
We generated an IBIS model from ISE for signal intergrity analysis.
In the IBIS model, the DCI pins are assigned with a model name LVDCI_33_50ohm_O / LVDCI_33_50ohm.
understanding here is the modle got generated with the default DCI termination resistance of 50ohm.
We are facing some overshoot and undershoot issues when simulating.
Is there any way to change/configure the DCI resistance?
we have tried the following constraint, but there is no change in the results.
INST pin_name DCI_VALUE = integer;
Can any body help us.
