I need Matlab codes for Antenna design
TI-89
Junior Member level 1
matlab antenna
Such as
Impedance vs Frequency
Directivity pattern
Elevation pattern
Radiation impedance vs. wavelength
Others
antenna design using matlab
it depends completely to the antenna and the parameter you want. there are a lot of matlab programs at mathwork site you can use
antenna matlab code
this link is not working .
h**p://www.ece.wpi.edu/books/aemm/index
This is the site of Makarov's book about Antenna and EM modelling with Matlab.
can anyone post the new link for this book.
thanks
antenna design in matlab
hello
I am not sure it's the same material covered in the book. it seems they're working on a new related em analysis with matlab project, see: **broken link removed**
best regards
antenna array matlab code
The working link to the codes should be:
More information about the ebook itself:
Best regards,
rotman lens antenna design using matlab
this is another site that contents so many Matlab codes about ur requirements!
h**p://ece.rutgers.edu/~orfanidi/ewa
I also feel glad to send u this pdf book if anyone need. Its name is ELECTROMAGNETIC WAVES AND ANTENNAS - Sophocles J.Orfanidis
adaptive antenna matlab code
manoelleoemi said:
you can download in
rapidshare.de/files/22596605/Mahafza__Bassem_R._-_Radar_Systems_Analysis_and_Design_Using_MatLab__CRC_Press_.rar
i cant download from it.
is it the link still function?
hope can help to get this
