Hw to Install Hspice 2004 or Hspice 2003 on Ubuntu 7.10
midgariano
Newbie level 6
Newbie level 6
hspice ubuntu
I'm trying to install Hspice 2003 and 2004 on Ubuntu 7.10 but it's impossible for me. Please help me whit this.
Thanks a lot.
hspice 2004
The simplest way is just untar the ".tar.gz" file, and then untar the ".taz" files. You will get a usable hspice -- although the directory structure is slightly different with that created by synopsys_installer.
If you use synopsys_installer, you may need to modify the shell scripts in installer.
hspice for ubuntu
First u need the libraries I attach to u.
For HSPICE 2003:
expand the compressed file
get into the new folder
>> cd 2003.03
Rename the folder RH72
>> mv RH72 linux
Run the installation script
>> cd bin
>> ./config
Agree all the licence terms and continue
then choose configure hspice
DONE the first part
Now create the folder:
>> mkdir /usr/local/flexlm
>> mkdir /usr/local/flexlm/licenses
Copy the licence
>> cp license_Hspice.txt (or something like this)
/usr/local/flexlm/licenses/license.dat
Now create the executable link
>> ln -sf /where u installed/2003.03/bin/hspice /usr/bin/hspice
DONE, now u can check hspice with some file in the examples folder.:idea:
Reactions: nanock
    nanock
hspice 2003 install linux
I agree to what you say but when i run spice it gives an error saying licence not found.
can u elaborate on what to do and what exactly shall be the directory structure.
I am not able to see any licence file as well...
please help
lm_license_file ubuntu
The license file must be defined in an environment variable called LM_LICENSE_FILE which has to be set before run spice.
Reactions: rbh
    rbh
ubuntu hspice
for that probably the licence file should be present some where... but I cannot see it...
by the way which version are u using and where did u get it from.
I need to install Hspice for linux, but I can't found it. Where I can download it?
I search for Hspice linux version. Where can find it?
nice to post in this by braydon and information i got
NO SIGNATURE LINK ALLOWED, THIS IS A WARNING
