cdober
Newbie level 2
Hi All,
I have a 300v supply which I need to monitor for leakage current. I need to sense >300uA leakage (+/-5%) and produce a low level (2-3v) indication for a microcontroller. Power consumption needs to be under 100uA, and the circuit must be able to withstand a fault (short) at the output of the 300v supply.
Before anyone freaks out about shorting a 300v supply, it's a low level pump circuit charging a 2uF cap :smile: .
I've tried a couple of discrete circuits, but process variations of the components limit accuracy. Integrated solutions give me problems with the fault protection end of things, in that the sensing element develops an instantaneous voltage that will kill the amp.
Any ideas would be most appreciated!
Thanks in advance for your time,
Cliff
Cliff
