Bianconero
Newbie level 6
Hi, I'm a newbie here, but decided to write my first post on edaboard, cause I encountered a problem I can't handle. I designed a switching PS to drive some Nixie tubes. Here's the schematic I've tested in LTSpice and it worked like charm:
I made a PCB, soldered all the parts and obviously it's not working. The input voltage is 12 V DC, the output should be adjusted using pot R36 between 170 V - 210 V DC.
I measured a couple of values with a DMM and an oscilloscope:
- the reference voltage is 5.02 V DC (seems ok)
- the output voltage is 11.7 V DC (instead of ~190 V DC)
- on 4. pin (RT/CT) there's a 210 kHz signal of charging and discharging the cap C18 and it changes from 1.5 V to 3.1 V (but the datasheet says it should be between 1.2 V to 2.8 V, LTSpice shows that, too)
- the feedback pin voltage is about 400 mV DC (I guess it should be around 2.5 V DC)
- the compensation pin voltage is about 6.7 V DC (?)
- the output pin stays low, so the MOSFET is turned off and the current control pin is also at low state
I'd be really grateful if anyone could help me find out, what's wrong with this circuit. Is it possible that the IC is broken or is it more the problem of the PCB design itself? I don't have any ideas.
