HSPICE- lic: No 'set LM_LICENSE_FILE' in current environment
joehwang
Junior Member level 2
a question about HSPICE
When I simulate LNA, I met the following message in the output file:
lic: No 'set LM_LICENSE_FILE' in current environment'
I have correct the path of the license and changed the environment variable.
Other than this, everything is good. I can still run the frequency response...etc.
What does this mean and does this message matter?
If you are using a Linux version find the response in my last thread:
Else, if you are using a windows version then I cant help you since no one replied to the question.
Re: a question about HSPICE
if you are using Linux and a bash shell do this,
export SNPSLMD_LICENSE_FILE=/path/to/license
or
export LM_LICENSE_FILE=/path/to/license
LNA... are you using Hspice RF ? Are you sure you have a license for the RF part ?
If under windows, then there's an answer in the other thread
INSTALLATION GUIDELINE (FOR HSPICE):
1. INSTALL TO Drive:\synopsys
2. COPY AVANT.DAT TO Dricve:\ synopsys
3. GO TO PROPERTIES OF MY COMPUTER-->ADVANCE-->ENVIORMENT VARIABLE-->NEW--
>SET: VARIABLE NAME=LM_LICENSE_FILE
VARIABLE VALUE=Drive:\ synopsys \AVANT.DAT
****NOTE: PATH COULD NOT INCLUDE SPACE
