s.h.bagherzdeh
Newbie level 2
Hello everyone
I want to have a VCCS. I used the Howland current source design.
I need to control load current by adjusting input AC voltage. I need a constant current in the frequency of the input. The current 1mA.
Based on the theory, I set the R2=R4=1Kohm and R1=R3=2Kohm. The load is in the range of 100 ohm to 100kohm. The op-amps I picked up are TL072CN and TL074CN. The VCC,-VCC of +/-15 V and +18/-18 V. The max input vo ltage amplitude is 3.75V. The frequency of 10Khz. But when I implemented on the breadboard and tested it, I could not get the the constant value for current source above 500ohm!!!!!!
If you could help me to solve this problem would be great...
