mpatel
Member level 4
I implemented Block RAM from Xilinx IP CORE (size 16384 entires, 16 bit each). The question is how can I watch what is stored inside the memory at any stage of simulation?
hys said:You can use "Chipscope" from xilinx.... you need to determine before compilation what signal you want to be able to observe. Then you connect the memory signals to be observable. Then during runtime it is possible to observe them...
You need to read through the Chipscope manual...
Best Regards,
Harish
h**p://hdlplanet.tripod.com/
h**p://groups.yahoo.com/group/hdlplanet
mpatel said:Thanks hys,
But my question was different. I need to watch memory contect during simulation and not during hardware validation. I mean when I simulate a design, which has memory block, with ModelSim. I know the method where I can observe the output signals from memory but it gives opportunity to observe serially once at each clock cycle. I want to watch a complete memory, like what is stored at which address at once.
