How to verify the start-up circuit in a bandgap??
Sam81
Newbie level 1
Newbie level 1
start up circuit
I'm designing a bandgap and use a classic start-up circuit, but I have problem of how to make sure if it works. Without the start-up circuit, the bandgap still start to work after the supply voltage ramps up. So how to simulate the practical situation? Thank you so much.
bandgap startup
Transient simulation + Monte Carlo + Process Corners
Oh, its very simple, charge the nodes to zero, the nodes the start-up circuit has to charge. PMOS gates will get a VDD level and NMOS gates will get a VSS level. The problem with the normal sim is that it estimates the iniital conditions and arrive at the final value because there is a positive feedback inherently in the bandgap cirucit.
You can do the above test with and without a start-up circuit and I am sure that you will see the difference
hi,
use .ic statement to initialize the node and no need for startup circuit ....
you can simulate start-up circuit separately too.... advantage of using .ic is that it will allow you to do estimation of total noise in the Bandgap ref ckt. else with start-up it may pop error as start-up will have to have pulse source...
regards
nandish
Try to ramp your supply fast and slow ramp for your bandgap without startup and do the same thing on bangap with start-up. You will find that with start-up circuit, the bandagap will work in two conditions.
