how to turn the ring oscillator off ?
sevid
Member level 2
hi,everyone
"one of the inverters should be replaced with a NAND gate to turn the ring oscillator off when not in use."
i dont know how to turn it off just by a NAND gate.
how to connect the NAND to other inverters ?
plz help me.
thanks
sevid
NAND gate has 2 inputs right... take one of them as control input to the oscillator switch it to logic high and you got a inverter... The circuit continues to work as ring oscillator... when you switch it to logic low the output of it stays logic high and the ring oscillator gets turned off.... problem solved...
    sevid
