How to to plot the radiation efficiency vs frequency using transient solver of CST?
flashking
Full Member level 3
Hello
Is there a method to plot the radiation efficeincy vs frequency
using the transient solver of CST microwave studio ?
it exists in the radiation pattern but only vs theta or phi for a single frequency
thanks
Transient Solver has nothing to do with your problem ,
Radiation efficiency is the ratio between realized gain and directivity --> Rad_eff = Direc/realized_gain (linear).
CST doesn't have a function to plot it versus frequency since it requires gain and direc for each freq , which are selected manually via the fields monitors.
You can plot it manually , take the results of 10 farfeilds for exp , and do the rest in matlab or excel.
Anyhow there is another function called "delivered power" which plots the Radiation efficiency of the IEEE gain (1- S11^2) counting only the adaptation of your port , not counting the dielectric or conductive losses in the structure.
Go to macros -> results -> Calculate delivered power
If you are working in a lossless environment (PEC) this function should get it done :grin:.
Just a small hint , Radiation efficiency is not correlated to theta or phi :|.
Hope that helps
Hope that helps
the second method looks interesting , I will try it
thanks for replying and helping:grin:.
Any other suggestions ?
