how to solve parameters error in the assura
devenders
Newbie level 2
Hello All,
I have to generate dspf file of register file 64x17.i clear the lvs by using calibre and when i use assura to clear lvs than there is parameter error.
I check the particular transistor length and width and found both parameter correct.
Now, how can i remove this to generate dspf
If you slid that scroll-bar to the right it should tell you what
discrepancy it thinks it sees. At least, this is true on the
older version of Assura I've been using. This would be your
clue, much more valuable than clueless guessing.
dear dick,
initially we are using 5.1 version of cadence but from last month i am using 6.1.5 version of cadence and in this regarding parameter error i had checked length and width of every transistor in particular error block but there were no error and also check the instance library of the transistor this was also same so getting no idea how to remove ,if you have any idea at least around the error, than please help me
