How to set a cpw-fed waveport ?
zhangjun
Newbie level 5
I want to set a waveport to cpw-fed antenna ,this model is the cpw part,the characteristic impedance of this cpw is nearly 50Ω,I want to get the s11 very small and the s12 to 0dB,but i don't know how to set my port ,can any one help me ,thank you very much!
a cpw fed port set
Take a look at this topic
and download port_tutorial file to get solution for your problem
cheers!
a cpw fed port set
thank you very much for your advice,I have download this file early.But I have not solve the prolem !My ,teacher said the waveport was not correct ,the s11 must quite small !
a cpw fed port set
zhangjun@
After I inspected your problem, there're some more advices:
1. You should read Port_tutorial file more carefully once again.
2. Use a 2D object (Rectangular) instead of 3D object like you did for Wave_Port assignment.
3. Integration line must direct from one side ground plane to Signal line.
Let modify your structure as my recommendation. I believe you'll success.
Hope it helps
Re: a cpw fed port set
Hi zhangjun!
As nhomuathu_hanoi suggested, please learn first how to setup waveport in HFSS. I've updated your file and attached here. You requirements are fulfilled I guess.
Regards,
Shameem
