joyceliu2010
Newbie level 2
How to save electricity when computer standby?
Some good advise? ..........
selfreliance said:Hi there! Good for u being conscious of saving electricity. Well, while your pc standing by, turning off the monitor will score a point. Lol,that's more than easy.
joyceliu2010 said:selfreliance said:Hi there! Good for u being conscious of saving electricity. Well, while your pc standing by, turning off the monitor will score a point. Lol,that's more than easy.
Ow, ic .thx.......
joyceliu2010 said:How to save electricity when computer standby?
The most efficient method is to not have the computer on at all - instead have a dedicated device to remove the power - I think it's called an off "switch" ?
Sorry! I couldn't resist that.
Seriously though - if its mains powered a solid state
switch can remove the power almost entirely and be triggered by anything you like.
If it needs to be on standby specifically - as selfreliance said - make sure the monitor goes off
and the drives spin down. (Anything mechanical always uses the most power)
Depending on what hardware you run and the OS -the CPU should also go to a low power sleep mode.
If you have other peripherals - maybe an external drive or something make sure they go off too.
ANy plug in cards like TV devices should be shut down to stop them "waking" the system unexpectedly as should WiFi and modem connections etc.
Its pretty much common sense stuff - just turn as much of it off as you can and only let one thing wake it up again.
jack
