U don't say what language u are using. My example is in VHDL. I hope it helps u.
flashIO<=flash_data when write_en='1' else (others=>'z');
flashIO is an input/output dataport to the flash. When the signal write_en='1' the flash_data appears at the output. during write_en='0' flash_IO is tristate and the flash can put its data on the bus. Reading from the flashIO port is possible all the time.
U have to add your control signal like CS, OE ... etc.
