How to program PIC10fxx microcontroller
wisely77
Member level 4
Member level 4
hi,
anyone got any idea how to program pic10f2xx uc?
can we use jdm86 to do that? how?
what prrogrammer? as i know icprog and ponyprog don't have these uc in its list.
thanks.
wisely
pic10f programmer
I just build one yesterday. Im using ICD2 with MPLAB and Hi-t*ch compiler version 8.05. Works fine and you can program the PIC10F without any problem.
Good Luck.
pic10f200 programmer
Can I program pic 10F family in the circuit?
pic10f program
Yes,
But you will need to add resistors 4.7K between the PGD and PGC lines to your circuit board. i.e The programing lines will not be interfierd from your external hardware. If they will, then you will not be able to program the device correctly.
icprog pic10f
wisely77 said:
hi,
thanks.
wisely
The Epic programmer will program them, although the
adapter is going to cost more than the programmer. :(
Nick
pic 10f programmer
Another idea:
I have just read in the Microchip Forum, some guys are using the JDM + ICPROG to burn the 10F PIC series. They found that to burn them, we have to select the 12C508, load the hex and burn the 10FXXX. But it was impossible to erase or to reprogram them. So if we select the 16F877, we can erase the 10FXXX. I have not tested yet.
programing of pic10f
Why not use BFPM USB ICSP programmer from microchip ?? ;-)
See you
pic 10f programs
Another idea:
I want to flash it with 10F202
Have you tried out the method yet? does it work? program using ICprog by selecting 12C508 and erase it using 16F8777.
pic10f200 prgrammer
Try this software. It is good and fast
Cheers
Ravi
pic programmer 10f200
I was wondering, is it possible to use WinPIC800 to program 10F with ProPIC2 hardware.
Thanks
