njxia
Newbie level 5
I want to generate a 10MHz oscillation signal with its amplitude swinging from -5 v to +5v. I want to use a crystal oscillator to create the 10 MHz signal. However I find the typical voltage swing for the crystal oscillator signal is single signed, i.e. from 0 v to 3.3 v. Could you suggest a solution how I can make the swing from -5v to 5v? What devices that I could use? Thanks in advance.
