How to load the libraries from 4.1 version to SOC encounter 5.2?
vreddy
can anyone tell me how to load the libraries from 4.1 version to SOC encounter 5.2 version.......
i have copied all the libraries to one directory but it s not working.........
can 4.1 version libraries run in 5.2 verson..??? or else we need to go for the new lib??
in terminal i can see the copied lib but when i'm importing the same their i cannot see the copied lib...?? y so?/
thanks
vreddy
Re: encounter
The synopsis libraries are compatable to the Encounter versiions like 4.1,4.2,5.2,.......6.1...
There no need to change the lib's. Check wether you are giving correctly or not.
If any problem let me know.
Narasaiah
encounter
Hi first i write the problem as i understood
you have copied the *.lib to dir X
while you importing those lib's using gui you are not able to found them
is it?
